IDLE LEARN PROCEDURE
Do I have to perform an IDLE LEARN PROCEDURE after I install my C.A.I.?
There was mention of this in the instructions from callaway. If I do, how is this done? Thanks :D |
RE: IDLE LEARN PROCEDURE
Insert key into ignition and turn to the "On" position but, DO NOT START THE ENGINE.
Pop open the engine fuse block box cover and remove the two 10amp fuses from position numbers 16 & 23. Your DIC will now display "check" messages for ABS, etc... Turn ignition to the "Off" position. Re-insert both 10amp fuses for positions 16 & 23. Start your engine Allow engine coolant temperature to reach a minimum of 176 degrees F and run at this minimum temperature for at least 5 minutes. Shut down engine Let rest for a minimum of 30 seconds. Restart engine - check for DIC error codes (there should be none). Drive car for a minimum of 30 miles at varying rpm settings and speeds. PCM will now re-learn and adjust for the new air flow and air temperature at the intake. |
