My 98 won't start, low voltage on dash
#12
RE: My 98 won't start, low voltage on dash
Thanks CG
That makes sense about the VATS.
I am believe it may be the ignition switch, I don't have full voltage at the fuse when the ignition switch is ON. I will be replacing the ignition switch this weekend and will let everyone know how it turns out...
Thanks for the replies
#13
You gotta' getta' wiring diagram, and find out where the power and ground is for the circuit that controls the items indicated on the system console.
GM in the late '90's (and maybe earlier, and maybe early 2000's), have several electronically-controlled items on one 'circuit'. For example, my '98 GMC (GM) has one circuit called circuit 1020, which is 4 wheel dr controller, tranny controller, dash guages, and a few other items also. If you lose power to the circuit, codes for each item light up, even tho' each item works fine.
You gotta' get the wiring diagram. Before buying haynes or chiltons, go to the public library and check their copies.
You can do it yourself, OR, pay the dealer to do it.
#14
ORIGINAL: myc5
Thanks CG
Thanks CG
#16
ORIGINAL: cwb
Why you gonna buy a new ignition switch?
ORIGINAL: myc5
Thanks CG
Thanks CG
I WOULD BE WILLING TO BET THIS WOULD HAVE COST ME ABOUT $600 AT THE DEALER.
SO IF ANYONE SHOULD HAVE A SIMILAR PROBLEM, KEEP THIS IN MIND.
THANKS FOR THE REPLIES!
BTW....THE SERVICE MANUALS I HAVE CAME IN VERY HANDY.
#17
I like you have not been here in a while but if your still having problems respond,and Ill send you some info that helped me. But like I read someone else state that this is a common problem among C5's
#18
Thanks, I did get it figured out. It was the ignition switch and ended up changing it out myself and saving quite a bit of money that way. Bet the dealer would have charged a pretty penny for it, as there was quite a bit of labor involved just getting the switch out.
shaggy34994
02-21-2013 09:05 AM
