Over heating
FYI! I had a problem with overheating, turns out the fitting for the return line to the overlfow canster was bad. While driving, the backflow wouldblow out the bad fitting, loosing water! If you keep adding water/antifreeze check the hose fitting. I bet it is loose.
Thanks for the tip!
