shock replacement
Hi Gang
I just replaced my GM shocks that have the ride control valves with some standard shocks I get a better ride but the DIC keeps flashing 'Shocks Inoperative' Max Speed 80 MPH' Is there a way to fool the computor by pulling a relay, or should I just cut the electical connetor from the shocks, solder the wires together and plug them back in so the computor sees a complete circuit? I am sure that someone has had the issue before and fould a soulation Thanks in advance Found solution but can't seem to delete this post |
