WHATS THE BEST INTAKE FOR Z06 LS6 !!!
Old 11-13-2008, 01:31 PM
jerseyc5's Avatar
Default WHATS THE BEST INTAKE FOR Z06 LS6 !!!
HEY GUYS I DID A LS6 SWAP INTO MY 2000 PEWTER COUPE ALONG WITH THE Z06 SUSPENSION,, NOW ITS TIME TO SEE WHAT THIS BABY CAN DO.. STARTING OFF WITH THE AIR FLOW.. WHATS THE BEST INTAKE AVAILABLE I I HAVE A CUSTOM COLD AIR IN FRONT OF THE RADIATOR LIKE THE VORTEX SN HONKER STYLE PPL TELL ME THATS THE BEST... THEN AGAIN I LIKE HALLTECHS NUMBERS TOO ?? WHAT DO I CHOOSE FROM YOUR EXPERIENCE ?? ALSO WHAT THROTTLE BODY AN MASS AIRFLOW SENSOR ARE THE BEST...
THIS SHOULD START UP SOME GOOD COMPETITIVE CONVO,,,,
[IMG]local://upfiles/7183/AD9C5288B00D4E409DDA22CA0C480029.jpg[/IMG]
Old 11-13-2008, 03:15 PM
Dave01's Avatar
Default RE: WHATS THE BEST INTAKE FOR Z06 LS6 !!!
Callaway Honker is certainly one of the best in terms of quality and performance. Vararams are popular, but are not quite in the same league, qualitywise. I'd stick with the same MAF and TB - you won't gain much with aftermarket ones.
Do you have an aftermarket exhaust system? You can chop 20 lbs just by getting rid of the heavy steel OEM CAT-back stuff. Hopefully, you already trashed your runflats. Running non-runflats will save you 24-28 lbs of unsprung weight.
Old 11-16-2008, 07:52 PM
You said you went to a Zo6 suspension: just what parts did your replace/get rid of?
As to the engine, the exhaust is the place to start but the intake will not make that much difference regardless of what it is.
First: a good set of long tube headers. A must.
Second: A cam/springs/retainers/rods/rocker arms set, frolm a good source like Crowler, and a really good tune, would wake the engine up.
Old 11-17-2008, 02:34 PM
Dave01's Avatar
Of course, all of what Lee recommends depends upon your State's smog requirements. Here in CA, long tube headers are illegal and a heads/cam setup can push your hydrocarbons over the limit.
Lee, I've seen gains of 10 RWHP+ from aftermarket intake filter systems, quite a few times, my C5, included. Having a true cold air intake is best, since it pressty much eliminates ECU detuning due to high intake air temperatures.
Dave
Old 11-18-2008, 11:05 PM
jerseyc5's Avatar
i already have long tubes and exhaust done by vette doctors they did my cold air too all custom no brand name they cut my shroud an put the k&n filter in front of the radiator for max cold air but i have the stock power duct an coupler....
Old 11-19-2008, 09:26 AM
Dave01's Avatar
Sorry, I thought you were referring to an air filter/intake system. Lee is correct, a different intake manifold will not make that much of a difference. What you have for your air filter/intake system is probably fine as long as your filter is good. Check your throttlebody opening every year or so to make sure it is clean. Other than that, 3.90s or 4.10s will get you some better acceleration numbers.
jerseyc5
05-15-2009 03:27 PM
07zx6arrrr
09-16-2008 08:41 PM
firefightergib
12-21-2006 06:45 PM
VenomInside
09-02-2006 12:07 PM
zzz06r
12-10-2005 10:11 PM
Quick Reply: WHATS THE BEST INTAKE FOR Z06 LS6 !!!
