Tire Wear
I just put new tires on my 04 because the inside tread of my passenger front tire wore to bald. I took it to be alligned at a reputable Chevy dealer specializing in Vettes and they found only minor out of adjustments, butit was worseon the drivers side. Now I'm worried about the new Michelins. Any thoughts ?
RE: Tire Wear
If the inside tread is worn than the camber is off. If they found this and adjusted it then you should have no problems. What exactly did they adjust?
