Tuner
Has anyone used the Diblo Predator tuner on the Z06 405HP, if so what HP gain did you see and what tune did you use?
George |
RE: Tuner
take your car and get it dyno tuned instead of using the plug and go type
RE: Tuner
Does anyone know of any tuners that are good for C5 Corvettes in the Orlando Area?
Chris |
RE: Tuner
Since every engine is different you cant really tell what your gains will be... like cobra said, your best bet would be to have it dyno tuned...
If you plan on doing any other mods you should do them first then have it dyno tuned, that way the tuner can map your car according to your mods installed, making it run better. |
RE: Tuner
tuners are a waste of money save ur money and buy a supercharger :D
RE: Tuner
Central Florida Turbo is excellent, probably the most knowledgeable staff I've ever seen. Check them out.
