wet carpet on passenger side
anyone have this happen to them. after a heavy rain i noticed the floor board on passenger
side of my 97 vette was soaked, but window was up and no signs of water on door panel or on the seat,where could this be coming from,any ideas will help. thanks |
RE: wet carpet on passenger side
I've heard of this happening due to old/worn door seals.
I get a little water in my car from bad weather stripping on my targa top. I suggest the next time you wash your car, take a peak inside and see if you can pin-point the leak.
targa top weather strip [rear]
There's a drain hose for the cowl indent on the passenger side that can be blocked. (There's also 3 bladder drains on the driver's side as well) Jack the front up, pull the right wheel (foryour problem). You'll see an access panel in the wheel well. Pull it and you should be able to see a serpentine drain line that runs down past the battery compartment. Make sure it's clear. If it clogs you'll get water backing up and into the passenger foot well. Same on the driver's side if the bladder hoses clog with leaves, etc. There's an access panel on the left wheel well as well.
Also check the A/C drain line, it's on the passenger side also. |
