what code is PO442 on a c5 2001
this code cam up as the check engine light came on it was the code PO442HC i cleared it and the engine light went off any ideas what this is?????
RE: what code is PO442 on a c5 2001
This may be a little late but code PO442 is for a small leak detected in the evaporative emissions (EVAP). The information is from the GM 2000 Corvette shop manual. Possible corrections: 1. loose, incorrect, or leaking fuel tank cap 2. disconnected, improperly routed, kinked or damaged EVAP purge lines 3. damaged EVAP component 4. damaged fuel pressure connection valve or a loose, missing or damaged dust cap.
If you are the do-it-yourself type, there is a complete trouble shooting guide in the GM manual. The guide is fairly simple with no exodic tools required to trouble shoot this code. |
