Code advice or help
I have a 2001 vette and lately it has been showing service traction, abs, tire pressure sensors, ect.... I have pulled my codes and its showing quit a few to still be current wich are p0530 " Ac refrigerant Pressure Sensor Cirtcuit." C1214 " Sol Valve Relay Contact or Coil CKT Open (TGS)" C2115 Left Rear TPM Sensor Malfunction." and B0361 " Left Actuator Feedback Short to GND." I need to know is someone has had this same problem and how did they managed to get it fixed without having to do to a stealership.
Thanks :D |
RE: Code advice or help
In a similar situation on my '02 ZO6, my local shop had an electrical wizard who just walked through the servcie manual on each code and replaced the parts per the manual. It fixed the problem.
