differential lubricant additive
gm recommends adding additive to the rear end when replacing all of the differential fluid.
can someone explain why additive is needed, or is it just a suggestion? thank you |
RE: differential lubricant additive
so does dodge...the rear diff is always under a GREAT deal of stress..im not even certain of what the additive is, i think that it is just a seal/gasket refresher of sorts.
Whatever it is, I'd add it. Its there for a reason.
Thd additive is to make the limited slip clutches in the differential from sticking together when turning corners. It essentially makes the lube slicker. If you didn't have it, you would here a clacking noise when you go around corners. [8D]
ORIGINAL: mech259 Thd additive is to make the limited slip clutches in the differential from sticking together when turning corners. It essentially makes the lube slicker. If you didn't have it, you would here a clacking noise when you go around corners. [8D] |
ORIGINAL: Terry S ORIGINAL: mech259 Thd additive is to make the limited slip clutches in the differential from sticking together when turning corners. It essentially makes the lube slicker. If you didn't have it, you would here a clacking noise when you go around corners. [8D] |
