C6 Headlight Problem
My '05 C6 has headlight problems. I can't get my lowbeams to turn on. My highbeams work. I have replaced the battery and all of my fuses and relay are fine. I can get the lowbeams to turn on occassionally, but they mostly do not turn on. I can't figure out why. It is happening to both lights simultaneously.
Does anyone have a clue? Regards, |
What about the switch itself?
Difficulty of checking switch
What level of difficulty is it to check to see if the switch is bad? Does it come apart fairly easily?
Interior Door release buttons not working
I don't know if this is related to the headlamp problem, but I have an additional electrical problem. The interior door release buttons no longer work. The only way to open the doors from the inside is by using the emergency release handles. This problem started shortly before the headlights started failing. Could these problems be related? How do I address the door problem?
Regards, Rob |
Originally Posted by whitec6vette
(Post 61666)
I don't know if this is related to the headlamp problem, but I have an additional electrical problem. The interior door release buttons no longer work. The only way to open the doors from the inside is by using the emergency release handles. This problem started shortly before the headlight started failing. Could these problems be related? How do I address the door problem?
Regards, Rob |
