Exhaust help
Recently bought an 09 c6 z51. It’s has kooks long tubes with kooks 3” catless x pipe kit and a stock z06 NPP muffler (valves permanently open)I like the sound but the drone is pretty bad. I’m thinking about replacing the mufflers with something else. Would a muffler delete be too loud with the current set up? Or should a try a different set of mufflers? Thanks for any advice
Welcome to the forum. Straight pipes with no cats and mufflers would definitely be louder. Can you reengage the NPP valves? Or you could check with Kooks to see if they make a muffler for your setup.
