Corvette C6 Forum 2005+
Replace radio?
Old 08-17-2018, 10:16 AM
pinopinopino72's Avatar
Default Replace radio?
My CD player in my base radio is jammed and the paint is chipping off one of the memory buttons, so I think it's time to replace the radio. Should I go with aftermarket or just get a stock one from the Web? Would I be able to get the one with the navigation and touch screen (i.e. is it the same connector as the base radio?)
Old 08-18-2018, 08:58 AM
I doubt the connectors match between the base radio and the nav radio. Personally I would steer away from the GM nav radio because their early systems were rather sketchy. I think you'd find a Garmin to be a better alternative if you need an nav system. You could check with Crutchfield to see what aftermarket radios are available and they can also provide connector adapter harnesses.
Alans 94 vette
07-04-2022 10:22 AM
superdave54
11-08-2015 08:37 AM
dale
01-24-2008 09:27 PM
romeo04
12-26-2006 10:34 AM
jdavis
08-06-2005 09:58 PM
Quick Reply: Replace radio?
