Radio antenna
I have an 86 and the antenna will not turn off (removed fuse). How do you get to the motor drive to replace it?
Don |
RE: Radio antenna
SHOULD BE IN THE LEFT REAR QUARTER PANEL .JACK UP THE REAR AND SLIDE UNDER THE CAR AND LOOK UP SHOULD SEE IT THERE,YOU CAN TAKE OUT THE LEFT LIGHT TO AND SEE IT THROUGH THERE.[8D]
RE: Radio antenna
Thanks CK I'll give it a try
Don[8D] |
RE: Radio antenna
you are very welcome:D
