AWESOME 2002 Z06 Corvette - LOADED
I am selling my Black/Black 2002 Z06 Cporvette. I have approximately 26,400 pampered miles on the car. I have over $80K into the car. It is very well cared for. The shop where almost all of the work was completed is also available if you have questions as well. If you're looking for just a plain corvette, this is NOT the car for you. I am asking $42K for the car. If you are looking for a car that was done right, with no corners were cut, this is the car for you. See below for mods:
2002 Z06 Corvette Modifications: Ronal Chrome wheels 19” rear and 18” front Michelin Pilot Sport tires Baer Eradispeed disc rotors, drilled, slotted, zinc coated B&M Short throw “Ripper” shifter with carbon fiber shift knob Russell stainless steel brake lines QA1 Adjustable shocks Car lowered and has a performance suspension tune by Motor Sport Image Euro taillights Red/Clear Euro single element headlights Piaa Fog lights MSI Chrome Harness Bar with CROW 5 Point restraint system Padded center console lid Instrument Bezel Set Trunk lid cover Trunk center floor hinged lid Custom rear carpeting Chrome Z06 doorsills MSI Ground Protection Package (front skid protectors, side skirt protectors, front spoiler protectors) Adjustable Shift light integrated in “Heads Up” display area Motor/Drive Modifications: Chrome Magnuson Intercooled Supercharger – CARB Certified Smaller blower nose pulley to bump boost Interior Boost Gauge Booster fan for intercooler to help make air charge even cooler Spec 3 Clutch (650 HP rated) with steel billet 24 lb. flywheel and ceramic clutch housing 4.10 Rear differential (entire rear end) “Severe Duty Rated” Dyno tuned by GM employee with LS1 edit producing over 500 RWHP FLP ceramic long tube headers FLP X-Pipe FLP Hi performance (low restriction) cats GHL stainless steel exhaust mufflers with 4” tips (quad) High capacity “Be Kool” racing radiator Thermostatically controlled Engine oil cooler Custom grind COMP Blower cam with high performance springs and push rods Bosch 42 pound fuel injectors High flow fuel pump Custom air brushed theme “Smoothies” (wheel wells, radiator cover, fluid tanks, fuel rail covers) RK Sports engine hood VaraRam V1B air intake system with new upgraded air intake filter New Interstate “red top” Gel Battery Stainless steel hoses under hood with Russell fittings Audio: Alpine CDA 7998 CD/MP3/AM FM Tuner/CD Controller Head Unit with remote control Crystal Audio - CSC60S Two way Component 6.5" Speaker System w/ Silk Tweeters Crystal Audio - CSX510 Co-axial Component 6.5" Speaker System w/ Silk Tweeters Xtant 4.4 - 4 Channel 4-x 100 watt Amplifier Xtant 3.1 - Class "D” 1 x 300 watt Amplifier 2 - Xtant 1044 - 10" Hexagonal Subwoofers w/ Dual Voice coils Custom made sound box Extensive sound deadening material added in car Factory style automatic electric antenna Other: Lo/Jack System Hardwired for Valentine One Radar Detector Web site: You can see additional pictures of the car at http://www.motorsportimage.com E-mail me at atbatt@homail.com if you are interested in additional pictures. Please serious inquires only. [IMG]local://upfiles/1376/512DB0263A224AFB8999D3F0E1FF5948.jpg[/IMG] [IMG]local://upfiles/1376/D9B081B0CF61445D8E0C5822F8D76544.jpg[/IMG] [IMG]local://upfiles/1376/A548C763860F4603ADF55D87A92E9DD2.jpg[/IMG] [IMG]local://upfiles/1376/AB98B4CFF9BF41EA9895729E4F4B40FD.jpg[/IMG] [IMG]local://upfiles/1376/298CF2CC3C0D4077A3BA06CB927F2F4E.jpg[/IMG] |
RE: AWESOME 2002 Z06 Corvette - LOADED
SOLD
