C4 Transmission Trouble
Hi I have an '84 corvette which has the borg warner t10 with a doug nash automatic overdrive on the back in place of a tailshaft. Is it possible to use just a t10 4 speed? Will it mount correctly?.... Thanks
RE: C4 Transmission Trouble
Welcome aboard, The T10 will not fit, the tailshaft of the trans.for the c4 is supported by a beam that attaches to the rear dif.housing. Standard T10 uses a different cross beam support which is not interchangable.
