C5 Corvette oode P0155 Oxygen sensor
How can I tell which oxygen sensor to change when code P0155 is displayed? ie.which oxygen sensor is this referring to on the car? Can anyone explain exactly where this sensor is, I have the car up on a lift and can see the sensors but do not know which one it is referring to!
Thanks |
I'd replace them both, frankly. If your car is modified you might consider replacing them with dummy sensors, too: dummies generally don't fail and they give the correct impedance reading so the ECM thinks all is okay even if you run a bit off program due to the mods.
