losing spark on 66
i have a 1966 big block that will start about 50% of the time. i haveinstalled an electronic module, new plugs, wires and rebuilt the carb. i'm getting plenty of fuel but seem to be losing spark. any suggestions?
RE: losing spark on 66
Possibly coil,ignition resistor or "S" contacts in solenoid?
Ron |
I had a similar problem with a set of bad "carbonwire" plug wires I bought. Some brand named SparkEagle or something I had never heard of but it was recommended mistake. It was an expensive set ($80 or so) and fit well all the right lengths and such and looked good, but my '70 nevernever started well, although it ran okay once it was warmed up. Not sure what toe problem was, but I eventually replaced it with a Delco set (basically, stock) and that completely cured the problem.
