Oil pan hits steering
O. K., here's the prob.
When I went to set the 454 on the frame mounts, I could get the passenger side to line up, but then the driver's side lacks about 3/4 inch of lining up. This is due to the oil pan hitting on the steering. So,....my question is; What was the last year that 454's were put in Vettes? I figure if I get an oil pan from that year, it will solve my prob. |
RE: Oil pan hits steering
ORIGINAL: C3 Starship O. K., here's the prob. When I went to set the 454 on the frame mounts, I could get the passenger side to line up, but then the driver's side lacks about 3/4 inch of lining up. This is due to the oil pan hitting on the steering. So,....my question is; What was the last year that 454's were put in Vettes? I figure if I get an oil pan from that year, it will solve my prob. That might be the thing to do anyway, if not only to check engine mount/frame alignment... Do you have pics of where you are on this??? |
If you put a rubber mallet to the side of the pan, will you have internal clearance issues? Oil volume/oil level issues? 3/4 of an inch is a lot to take in, but what's your options?
I appologise for not explaing well enough. The oil pan is hitting the steeringrelay rod that crosses under the front portion of the pan. I wouldn't use a rubber mallet on the pan, brutality is not the cure. I want to do it right. I feel it will be a combination of the propper pan and motor mounts.I'd still like to know what years the 454 was available for Vettes. Not in '80, 'cause I can't find applications for that year. I believe '74 was the last year, but not sure
ORIGINAL: C3 Starship I appologise for not explaing well enough. The oil pan is hitting the steeringrelay rod that crosses under the front portion of the pan. I wouldn't use a rubber mallet on the pan, brutality is not the cure. I want to do it right. I feel it will be a combination of the propper pan and motor mounts.I'd still like to know what years the 454 was available for Vettes. Not in '80, 'cause I can't find applications for that year. I believe '74 was the last year, but not sure Seems strange to have a unilateral clearance issue, instead of all the way across... Brutality? Okay. If you can't find another application, then pull the pan, put a cutting torch to it, re-weld with the proper clearance, and call it fabrication. You should see some of the tricks they pull at Fountain Power Boats with marine fuel cells. The only reason you couldn't call it 'demolition', is cause they're gonna' USEwhat they're workin' on. But keep us posted on this. I'm curious... |
The relay rod connects between the left and right tierods, tieing them together. The relay rod also connects from the pitman arm to the idler arm. The tie rods connect roughly 12 inches from either end of the relay rod.
Fabricate?, yes, I can do that! ;)I have the tech and knowhow, but I would rather not, since the right parts are available. I just have to find out which ones are which. :eek: |
Correction, after crawlin' back under to give things a look, I see that the pan is hitting on the power steering cyl. where it connects to the relay rod.
ORIGINAL: C3 Starship Correction, after crawlin' back under to give things a look, I see that the pan is hitting on the power steering cyl. where it connects to the relay rod. |
The pan has three levels, stepped if you will,from the front, about 6 inches back,and then where the sump is. If the second level was the same as the front, there would be no prob.
After seaching through several online cats, and viewing some pics, I'm convinced that I have the wrong oil pan for the Vette application. I'm calling Summit's tech support today, to verify the propper oil pan. |
Hi Starship, 454 were offered from 70 to 74. Not sure if cars with power steering had a special pan, but I'm still looking for more info. PG
