Service column lock & engine shut down
i I own a 1998 C5 Im haviing problems with my serviice column lock that was resolve and stering wheel moves free but engines shuts down when i try to run it . Is there any form to by-pass the cut off system from the BCM?. Thanks
RE: Service column lock & engine shut down
im not exactly sure what youre asking...
After installing my service column lock by-pass Corvette C5 1998 steering wheel is free but engine shut off when i try to drive it, The question is how can i solve this problem? I think the BCM is probably receiving wrong information from the column lock by-pass... THANKS.
so something that you installed is not allowing the car to run,...correct?
if it was working fine before your installed the bypass, it's probably just the way in which you wired in the relay, if you let me know which wires you tapped in to I could possibly help. the only other thing it could be it the passlock resistor sensor in the switch, check the 2 wires that come off the front of the switch and run into there own 2 pin junction about a foot down the wire ( check to see if they became lose during your install that clean the contacts in the switch and on the key. good luck [sm=americanasmiley.gif]
Thank you I let you know if its works.
