new and in need of help
Hello everyone,
I have a 73 conv. that i have worked on alot. Am having trouble with the ignition starter switch. I can bolt it on now problem but the directions say there is a lock pin i need to remove after instalation and i have no idea where this is at. I hope to get a lot of help on here, from what i have seen in the past there are alot of great people here Thanx |
RE: new and in need of help
Welcome to CF!:)
I'm stumped on this one, but be patient, I know help is commin'!;) |
Welcome to the site. If you haven't already you might want to try and post this in the C3 section of the site. You may get a better response to your question. Good luck.
Welcome to the forum
I'm not quite sure what you mean by Lock pin, I hope you find the answer here however. |
I have a '73 as well. If you can post a picture of the switch installed perhaps I can compare it to mine and we can locate the pin to be removed. I'll check mine out tomarrow and see what I can see. I looked in my shop manual and could not find anything.
Are you referring to the tumbler or the whole assembly? Is your switch on the column?
There is a lock pin that you must remove to take the old switch out. Does yours have a telescoping s/w? You have to pull wheel, retainer, steeering wheel lock plate, turn signal switch to take out the pin.
