Corvette Forums - Corvette Enthusiast Site (https://www.corvetteforums.com/forum/)
-   Parts/Other Sales (https://www.corvetteforums.com/forum/parts-other-sales-25/)
-   -   427 Balanced rotating assembly (https://www.corvetteforums.com/forum/parts-other-sales-25/427-balanced-rotating-assembly-11675/)
RNR Racing 07-09-2009 09:44 AM
I have for sale a 427 balanced rotating assembly.
I ran this for approximatly 500 miles.
It consisits of a 7115 crankshaft, std rods/.010 mains. I have owned this crank from new and did not like the mains being on the high side requiring a .002 over size bearing.
Genuine dot 7/16 rods which have not been abused, balanced to .5gm big and small end. Green factory paint smear is still on these rods.
TRW open chamber std bore pistons with 1/16 ring grooves and 3/16 oil grooves. Pistons are balanced to .5gm . 12.25:1 compression with 074 aluminum heads or 026 steel heads.
I sold the block several months ago and don't have the heart to ruin such a nice rotating assembly by using it for drag racing purposes.
This assembly is in pristine condition needing no machine work of any kind. No disappointments. Install in your std bore block for a inexpensive genuine 427.
Contact me for further info at 405-317-1270 ask for RJ.
I also have a set of bare 291 rect port heads dated B 5 71 - E 3 71 and a std bore 289 4 bolt block with large oil holes above the oil filter dated 73, it was a factory LS6 crate block. All parts are in exellent condition. A 512 4 bolt block E 13 71 with a sleeve in one hole, honed to 4.320 and will stay this bore size, new cam bearings, was used in NHRA Stock eliminator 71 Corvette, I don't have the heart to ruin this block by using it for racing purposes.
I will trade the 291 heads for a nice set of bare 077 heads.
