450HP pump gas SBC
1 Attachment(s)
Complete 385 Stroker Engine
What is included: 450HP 385cid Chevrolet small block Flowtech headers with custom collectors Meziere 55gpm street/strip electric water pump Internal Specifications: Block: Seasoned 4-bolt GM 010 Casting (2pc rear) Crank: 3.75" Eagle Cast Steel crank Rods: 6.0" Forged crower sportsman Pistons: 4.040" SRP forged 1/16" Ring design Gaskets & Bearings: Clevite & FelPro Cylinder heads: 200cc Sportsman II iron heads Intake:Edelbrock RPM Camshaft: Crower solid flat tapped 242/248 duration Oil System: Milodon pan, P/U, and Melling Pump Timing Chain: Cloyes True Roller Valve Covers: Moroso with moroso breathers Valve train: Crower stainless Roller rockers & Comp heavy wall Pushrods Balancer: Pro.Series External balance Flexplate: External balance SFI Machine work and assembly performed by Windsor Automotive machine. This engine is nearly brand new, and was built entirely with brand new parts (Except the block), after a handful of drag strip passes, and 3000 street miles its being replaced by a big block. Take advantage of an excellent deal which includes the Headers exact combo (Capped with exhaust!) has gone 11.15 @ 117. Hear the engine run prior to purchase, and i will remove the engine at the time of purchase. NOT INCLUDED:Alternator and bracket, crank pulley, Distributor, Starter, carb, carb spacers. $3,450 Interested in Stacks of Paper ONLY, no trades. Attachment 2689 |
RE: 450HP pump gas SBC
"$3,450
Interested in Stacks of Paper ONLY, no trades. " does that paper have to begreen? cause I got box loads of white. LOL seriously...where are you located? and what is it in now? |
