Street/Strip Raced a guy from a light? Had that ride of yours on the timed track? Tell your story here...
High Performance Alignments and Corner Balancing
Old 04-30-2016, 05:40 PM
EVS Motors's Avatar
Default High Performance Alignments and Corner Balancing
What is corner balancing?
Corner balancing is the process of shifting the weight carried by each wheel to approach optimal values. Although some weight can be shifted between wheels by physically relocating parts or just simply adding weights to the vehicle, the corner balancing process is focused on shifting weight by adjusting the suspension spring height. Any relocation of parts should be performed before corner balancing begins.
Why corner balance?
A properly corner balanced vehicle will handle evenly in left and right turns. Unbalanced handling occurs when front-to-rear weight distribution is not equal for left and right sides.
In a symmetric out-of-balance vehicle results in a teeter-totter affect. If the imbalance is extreme, one of the light wheels may be completely off the ground even at rest!
Street cars are rarely corner balanced and typically have no provision for adjusting spring height. That's because their spring rate is relatively low, perhaps 100 lbs/in. With such low spring rates it would take a huge imbalance in spring height to have a significant affect on corner balance.
Performance and race cars may have spring rates of 300, 400, 500 lbs/in and higher. Corner balance becomes much more important due to the high spring rates - small changes in height greatly impact weight carried. Additionally, we are much more concerned with handling in performance and race cars so corner balancing becomes very important.
Corner balance goal
The goal of corner balancing is to have the same front-to-rear weight ratio for both left and right sides. Expressed as an equation, the target is –
LF RF
LR RR
Corner balance equation
This equation works for real-world cars that are asymmetric. When this equation is in balance, the vehicle will handle the same through left and right turns. That is the goal.
Notice that if the vehicle is symmetric the diagonal weights targeted by the Corner balance equation are equal! If the vehicle is asymmetric, the targeted diagonal weights are not equal.
How to Corner Balance
The process is to measure wheel weights and plug them into the Corner Balance Equation. In the real world the equation will never be in perfect balance. If the imbalance is outside acceptable range you will adjust one or more spring heights, re-measure the wheel weights and do another trial of the Corner Balance Equation. Repeat until the imbalance is brought to an acceptably low value.
Note that a vehicle with a lot of friction or binding in the suspension components will not deliver repeatable corner weights. The friction will resist all suspension movement preventing the corner weights from measuring true (also creates erratic handling). Fix any friction and binding before you corner balance.
Deciding which wheel to adjust is the key. Look at the left and right sides of the imbalanced Corner Balance Equation. Balance can be achieved by increasing weight of the front wheel of the low numeric side or increasing weight of the rear wheel of the high numeric side. Alternatively balance can be achieved by decreasing weight of the rear wheel of the low numeric side or decreasing weight of the front wheel of the high numeric side.
Which wheel you choose to adjust depends on how you wish to impact ride height. In general, adjust the wheel whose ride height varies greatest from your target height. Loading a wheel will raise ride height, lightening a wheel will lower ride height. If ride height is correct and corner balance is off, lighten one wheel and load another to maintain correct height.
The process is one of trial and error and with experience becomes intuitive.
As you consider which wheel to adjust keep in mind the following set of rules:
Rule 1 - You can't shift total weight between axles, LF + RF = Constant
Rule 2 - You can't shift total weight between sides, LF + LR = Constant
Rule 3 - You can shift total weight between diagonal measures, LF + RR /= Constant
Rule 4 - Adjusting any one-wheel weight will change all wheel weights
If your measurements are not repeatable check for friction and binding in the suspension, then readjust.
This explanation of Corner Balancing brought to you by: Chuck Moreland
Old 08-06-2020, 12:03 PM
philvett2019's Avatar
Hi I have a strange problem I just upgraded my wheels .19.9 front rear are 20 x 10.5 and now my passenger side wheel rubs when the car dips ONLY the passenger side ??? any Ideas
Old 08-11-2020, 07:23 PM
Thanks for the input But my problem is not the handing of the car but the fact that the passenger side (ONLY THAT SIDE ) is the side that rubs when the car dips not left to right when the car turns?
craigmelb1
06-12-2015 07:21 PM
pacevette78
02-20-2012 08:42 PM
JoeVetteman
08-13-2009 10:31 AM
kent1997
05-19-2009 05:17 PM
red90vettesc
04-11-2007 02:31 AM
Quick Reply: High Performance Alignments and Corner Balancing
