Vendor Group And Special Buys Vendors and Advertisers will post special group buys for our members here! Check it out.
Jet-Hot Headers - perfect solution for your Corvette!
Old 11-30-2017, 07:11 AM
carid's Avatar
Former Sponsor
Default Jet-Hot Headers - perfect solution for your Corvette!
If you're looking to make an engine flow exhaust better, pump more air and fuel through it, and get more performance from your Corvette, Jet-Hot Long Tube Headers will help you out. Jet-Hot partnered with Kooks to create these headers due to a shared reputation for sterling quality, craftsmanship, and performance.
Jet-Hot - Long Tube Headers for Chevy Corvette https://www.carid.com/jet-hot/jet-ho...e-headers.html
These headers are made of 409 stainless and then coated by Jet-Hot. The coating protects from erosion for 1000+ hours, distributes heat evenly, keeps engine temperatures considerably cooler, has a lower price point and a lifetime warranty against anything including rust. This process allows to decrease surrounding temperatures by up to 65% and gives the ability to withstand 1250°F surface temperatures.
Each header is designed to complement the firing order of the engine and has a special scavenging pipe to produce the most power. With Jet-Hot Long Tube Headers you can be sure you're getting an optimal air flow, better HP, superior torque and much more for every dollar you spent!
Use this link to find all Jet-Hot Products https://www.carid.com/jet-hot/
