Edelbrock® - E-Force Supercharger for Chevy Corvette
If you were thinking of turning your can into a real beast, nothing can help you better then a Supercharger. A supercharger is driven directly by the engine. If you’re ready for improved horsepower, the kind that will have your car known all over the town is a supercharger kit from Edelbrock.
Edelbrock E-Force Supercharger systems deliver excellent horsepower and torque in a complete, street-legal kit that fits under the factory hood. The supercharger assembly has been integrated into the intake manifold for a seamless design with minimal components, eliminating the possibility of vacuum leaks between gasket surfaces. Edelbrock's inverted supercharger assembly is uniquely oriented, allowing for an incredible amount of intake runner length for maximizing low end torque. Besides being a performance upgrade, it also have great look! The supercharger assembly and matching aluminum coil covers (on applicable systems) are black powdered coated for durability with highlighted fins and Edelbrock logo for a unique appearance that will give any engine compartment a custom look. It is available for the Chevy Corvette 2005-2012. E-Force Supercharger systems are designed to boost your Corvette to 554 flywheel horsepower and 515 ft.-lbs. of torque (with stock fuel pump) or 599 flywheel horsepower and 547 ft-lbs. of torque (includes high volume fuel pump): Edelbrock® 15740 - Chevy Corvette 2010 E-Force Supercharger http://www.carid.com/images/edelbroc...ents/15740.jpg Main features: - Bolt-on installation - Electronic PCM programming module, with application specific tuning - Integrated bypass valve for little to no decrease in fuel economy. What do you think about it? |
