Jet-Hot Headers - perfect solution for your Corvette!
If you're looking to make an engine flow exhaust better, pump more air and fuel through it, and get more performance from your Corvette, Jet-Hot Long Tube Headers will help you out. Jet-Hot partnered with Kooks to create these headers due to a shared reputation for sterling quality, craftsmanship, and performance. https://cimg5.ibsrv.net/gimg/www.cor...aa037fd272.jpg Jet-Hot - Long Tube Headers for Chevy Corvette https://www.carid.com/jet-hot/jet-ho...e-headers.html https://cimg4.ibsrv.net/gimg/www.cor...286fce4f6b.jpg These headers are made of 409 stainless and then coated by Jet-Hot. The coating protects from erosion for 1000+ hours, distributes heat evenly, keeps engine temperatures considerably cooler, has a lower price point and a lifetime warranty against anything including rust. This process allows to decrease surrounding temperatures by up to 65% and gives the ability to withstand 1250°F surface temperatures. Each header is designed to complement the firing order of the engine and has a special scavenging pipe to produce the most power. With Jet-Hot Long Tube Headers you can be sure you're getting an optimal air flow, better HP, superior torque and much more for every dollar you spent! https://www.carid.com/images/for-for...s-hotrod-3.jpg https://www.carid.com/images/for-for...rs-chevy-3.jpg Use this link to find all Jet-Hot Products https://www.carid.com/jet-hot/ |
