Rack and pinion
Old 09-13-2008, 05:11 PM
imb1987's Avatar
Default Rack and pinion
Hey all! Long time no see! LOL! The seals in my rack and pinion went bad I need a new one but i need to know if my car has a close ratio or standard R & P. how do I find out? Thanks All!!
Old 09-13-2008, 06:07 PM
cwb is offline
Default RE: Rack and pinion
Get your front wheels in the air.
Turn them all the way to the lock.
Mark the line that the wheel is making.
Turn the steering wheel one complete turn.
Mark the new line the wheel makes.
Measure the angle of the difference in the lines.
Divide 360 by the angle of the wheel directions.
If the wheel turned 90', it would be a 4:1 steering ratio. It will probably be closer to 10 or 12 to 1. tho. ...
Old 09-13-2008, 10:23 PM
JoeVetteman's Avatar
But still,it's possible to upgrade from the standard ratio to the higher performance one....just switch the whole rack,if you have the means...it MAY depend on the year,but,well,you never know....some standard steering racks had a 2 and 3/4 turn of the wheel,while the sport had 2 1/4 turns,which of course meant a better response behind the wheel....you may have to upgrade a few parts,like tie rod boots,but,it's all up to you...good luck!!!! Joe
Old 09-14-2008, 09:20 PM
imb1987's Avatar
Thanks guys!! I am replacing the whole rack so I might just upgrade the whole thing to the close ratio. I just don't want to order it and it be non-compatable!
imb1987
03-28-2011 10:45 PM
justc3s
08-30-2006 10:19 PM
fullmonty
06-17-2006 02:26 AM
lumpsdady
04-04-2006 06:40 PM
Clayton
01-25-2006 02:34 AM
Quick Reply: Rack and pinion
