Active Handling service...
I just bought me a 2000 C5 FRC but on the display it says to service the active handling. I don't want to take it to the dealer just yet but i was wondering what could that be?? It drives fine and the active handling is on and it seems to be working properly..What could the message mean??
RE: Active Handling service...
My 02 did this about evey 3 months but it never caused an issue. I believe it's caused by a bad sensor but I'm not sure which one. If you clear the codes from the DIC it might go away for quite some time. I also believe the sensor depending on which one can be a very expensive repair to a very cheap repair. I never did get mine fixed and never had one issue with it though.
I've heard a lot of things can make it go off...sometimes water gets where it's not supposed to be, a lot of them do have that sensor problem I've heard. One time mine actually was triggered by my motor running too hot...it was low on coolant, but once I filled it back to where it was supposed to be...drove around again andit turned off...they say almost anything can do it...
