Need help - oil pan gasket
Old 04-15-2006, 09:06 PM
lumpsdady's Avatar
Default Need help - oil pan gasket
Hey guys I am on my way back up from a crank shat seal/timing chain cover gasket replacement. I added oil and noticed what seem to be my clean oil seeping down over the front leaf spring bolts. What I need to know is to replace the pan gasket is can I drop the front suspension with out removing the leaf spring? I realy dread this job especily after Ive done so much work. So any help will be greatly appreciated.[X(]
Old 04-16-2006, 11:49 AM
Default RE: Need help - oil pan gasket
Yeah, I think you can get it out. I remember doing it and I did not remove the spring, but I may had had to loosen the motor mounts and move it a bit, can't remember.
blknblu68
05-20-2007 09:00 AM
WHIPSrx7
08-02-2006 06:16 PM
paulbon
04-04-2006 12:25 AM
paulbon
03-28-2006 02:52 PM
dph
02-16-2006 11:21 PM
Quick Reply: Need help - oil pan gasket
