Big Coolant Leak
Old 09-17-2014, 07:26 PM
Cageman's Avatar
Default Big Coolant Leak
Hey guys car was running warm(2003 Ann), ended up putting a gallon of dex in it. parked it on Saturday. Seen a little spot after I drove it Monday, came out this morning and there is a big spot to the back side of the passenger tire. Again it has sat for a couple days and then this spot popped up. What is under the box that you fill with coolant? Do these boxes crack or are the hoses there?
Thanks
Old 09-18-2014, 10:25 AM
While I am not all that familiar with the C5 plumbing, you may have to remove the coolant reservoir to determine where the leak is occurring.
Old 09-18-2014, 04:01 PM
USMC GY's Avatar
This just happened to me a couple months ago. Under the
Reservoir tank is a "T" coupling and both ends cracked inside the coolant hoses causing a slow leak. Got a new tank ($100 or less) and replaced it in about 10 minutes.
Old 09-18-2014, 07:38 PM
Cageman's Avatar
Discovered the plastic around the top hose nipple broke off and was coming from there. New box on it's way.
Thanks guy's
Old 09-18-2014, 08:59 PM
Welcome to the forum. And thanks for the solution.
PHILC
12-17-2008 07:57 PM
michaelreid
05-26-2008 09:24 AM
01-31-2008 05:59 PM
mraaron895
11-09-2007 10:43 PM
mattisano
06-23-2007 10:28 PM
Quick Reply: Big Coolant Leak
