RPO
Old Sep 15, 2008 | 04:59 PM
Redwhisper's Avatar
Default RPO
I am trying to locate the RPO's ,if they are still there, on my 75 Vette. Can anyone help with the RPO's factorylocations?
Old Sep 15, 2008 | 09:38 PM
Default RE: RPO
Only place I know of is the tank sticker on top of the gas tank. Have to drop the tank to get it. I found a copy of a line build sheet, which lists the options, stuffed up under the dash when I put factory A/C in mine.
Old Sep 16, 2008 | 01:10 AM
Wedge's Avatar
Default RE: RPO
Probably just as easy to lift the body! Its not that easy to drop the tank, and if you do, and the sticker is there, it will most definately be stuck to the tank strap. You should undo the rubber gasket under the butt flap... I mean the 'gas cap cover', and look on the top of the tank. You should be able to see it with a small flashlight. Mine was on the passenger side of the tank. Dont expect to find much... it is unprotected paper that is 33 years old...
Good luck,
Wedge
[align=left] [/align]
irish350
Nov 15, 2007 11:03 PM
rhopkin
Mar 27, 2007 01:38 PM
miller
Sep 30, 2006 03:04 AM
lowmile89
Nov 24, 2005 01:45 AM
