dynotuning anysoftware available?
Old Jan 16, 2006 | 04:45 PM
unclewilson's Avatar
Default dynotuning anysoftware available?
wanting to reprogramm my my eeprom or reflash and change some values any software i can down load to my laptop?
Old Jan 16, 2006 | 05:21 PM
Default RE: dynotuning anysoftware available?
Nothing free that I know of. You can buy a program called LS1Edit you can buy for the LS engined cars, and similar programs for other cars, but you have to know what you are doing to use it, and that is not easy.
Buy a copy of GM High Performance Magazine, there are various modules and reprogrammer kits you can buy that will let you play with a few settings, etc. That might be all you need. LS1Edit and the like is for really drastic changes -- it can edit the whole PCM.
Old Jan 16, 2006 | 06:28 PM
i know where i can buy some peeogrammers but i got a laptop there should be a hacked downloadable program need to reset my active handling delay
Old Jan 16, 2006 | 08:07 PM
I wouldn't tamper with that unless you know the entire PCM code map backwards and forwards.
If you don't like the active handle delay, I'd just turn it off (you can do that stock) but don't tamper with it, the program is intermingled with the engine management code set
Old Jan 18, 2006 | 01:36 AM
oh but i lpve the active handling but iit got a 3/4 second delay is that normal i thought it was suppose to be instant
Old Jan 18, 2006 | 08:26 AM
No, its not instant and you can't make it so unless you want to really screw up the car - back off on the stability tolerance window and it will be intervening every time the car shifts in a turn, etc.
Mine takes about 1/2-3/4 second to act, which is about where I want it anyway. It's saved my butt three times in four years.
Ken Cook
Dec 3, 2007 08:39 PM
hardworkinman
Sep 13, 2007 05:55 PM
Curious George
Aug 19, 2007 09:51 PM
stevie1dr
May 5, 2006 04:57 PM
