cooling problem
Old Jun 13, 2005 | 01:53 AM
madride's Avatar
Default cooling problem
I have an 85 vette, 180 deg themostat, 200 deg switch, the themostat is working fine, but the temp creeps up too high. Reaches 220+ cruising. Coolant temp sensor was replaced. Rad. cloged/bad? Also when hot rad. overflow res. not at hot mark.
Old Jun 13, 2005 | 01:23 PM
Default RE: cooling problem
do you have a clutch fan on it?
Old Jun 13, 2005 | 04:02 PM
madride's Avatar
it is the stock electric fan. I have had the car a while, and there has never been a problem.
Old Jun 13, 2005 | 05:59 PM
ok...sorry about the fan question...wasnt sure. do you know that the fan is working? how are you certain that the thermostat is working ok?
Old Jun 13, 2005 | 07:38 PM
madride's Avatar
The fans are working and the thermostat is new. Its a 180 when I was refilling the rad. at ~180 the collant started to flow into the engine.
Old Jun 13, 2005 | 08:41 PM
so it seems that you have proper coolant flow??
Old Jun 13, 2005 | 10:57 PM
madride's Avatar
I guesss, when the engine is hot shouldn't the overflow res. be at the hot mark? It is not so I' m guessing there is some sort of flow problem. The radiator is full though, but the res. doesn't change when hot. Is it possible that there is an air lock or something?
Old Jun 14, 2005 | 12:18 PM
i know of ways to check into this..but im a bit old school..so my means of diagnosing things are a bit "ghetto"...if youre feeling frisky...you could always remove the rad return hose (with the car cool as not to burn yourself) and see if you have water returning...
but that does make a mess, and if youre going to do that, i would suggest having a bucket handy...perhaps drain the antifreeze out, then try to send water through the system...
did you have some work done that may have caused this, or did it just happen all of a sudden?
Old Jun 14, 2005 | 04:09 PM
madride's Avatar
I think its flowing ok, but I'll give it a shot. This is kinda dumb question but, Which way do the fans blow. The rad. fan blows twords the engine, which to my knowlege it correct, I also have an aux. fan in front of the rad. Which is blowing away from the rad.(towards the bumper, seems to me to be the wrongway, but I haven't messed with anything around there, Thanks for your help.
Old Jun 14, 2005 | 04:14 PM
they should both guide air through the radiator.
