cooling problem
Old Jun 15, 2005 | 04:30 PM
  #11
RaTTicus's Avatar
Default RE: cooling problem
Hi i have seen more than my share of t stats that are bad outta the box, easy check is if car is hot grab top radiator hose and see if it feels hard, if it is t stats not opening wich would over heat. next is ur fan relay could be getting a bit off calibration coming on too late. another is air lock in system vettes are notorious for that. few tips may help ya.
Old Jun 16, 2005 | 04:17 PM
  #12
madride's Avatar
Stat is good , I made the fans com on early 195, How do you go about getting rid of an airlock?
Old Jun 16, 2005 | 08:13 PM
  #13
Patrick's Avatar
Administrator
you bleed the system..
Old Jun 18, 2005 | 09:43 AM
  #14
RaTTicus's Avatar
yeah bleeding system is like removing all trapped air in the systems high point. leave rad cap loose to start kust turn it so its on but not all the way,theres a half way spot u can feel. then run motorwhen its almost warmed up turn your heater on full blast,this will purge the heater hose lines.after than let cool. remove cap check and fill level replace cap fully,run to temp and open heater up full blast again. vettes like to run around 212 to 220 i think there are some egr sensors that require high temp to operate.
Old Jun 18, 2005 | 01:33 PM
  #15
Patrick's Avatar
Administrator
and on a side not, when you go to remove your cap...MAKE SURE it doesnt have pressure behind it...ive seen people get burned severely from anitfreeze...
Old Jun 19, 2005 | 01:19 PM
  #16
joe's Avatar
joe
I have a 1985 and have the same problem of temperature abaove 200. I have a 160 but can not maintain cooler temperatures. I have had other vetts with big blocks without any problems. I will be concentrating on the rad/condensor for blockage. Don't forget that the air is brought in form the street and any object could be sucked in. Other factors to concider is the temp of the trans which is also cooled by the rad. Will let you know my progress.
Old Jun 20, 2005 | 01:34 AM
  #17
madride's Avatar
After a couple of tries and each time being able to and more coolant each time I successfully removed the lock. My front spoiler was really effed up, so I ordered a new one, my head must have been in another place case the one that I had on there wasn't doing any thing, it was all busted up, didn't realize that it so important, thanks for all you help.
Old Jul 5, 2005 | 01:44 PM
  #18
joe's Avatar
joe
I have just taken my rad out and found that it was 1/3 blocked with leaves and a plastic bag. This will also let me clean the condensor for better a/c. This should solve the rising temp. Will let you know.
joe
Old Jul 22, 2005 | 11:23 AM
  #19
JLITTY's Avatar
Theres a few products in summit that are supposed to lower your temps by 40 degrees or so, pretty inexpensive and are added to the normal coolant. Ever try that ?
Old Jul 22, 2005 | 06:40 PM
  #20
joe's Avatar
joe
Thanks for the info. The vet is back together. Things I did. Replaced water pump only because I did not know the age of it(why take a chance). Cleaned out between the condensor and the rad, preasure wash rad and still could not remove all the little stones. Today was 90 degrees her in Virginia Beach and the engine temp. stayed below 190 with a 160 thermostat. Will be trying some addatives to see if I can get it cooler.
joe
oldtvman
Sep 21, 2012 07:29 AM
kuladog
May 7, 2011 09:16 AM
CStewTAMU
Dec 31, 2007 10:08 AM
Clayton
Feb 10, 2006 12:46 AM
75Shark
Dec 6, 2005 01:17 PM
