Starter breaking the block????
Old Mar 1, 2006 | 08:00 PM
zzz06r's Avatar
Default Starter breaking the block????
I have an '01 zo6. My starter went out the other day so i ordered a new one. Was going to put it on myself and saw what looked to be a break in one of the brackets that holds it on so i decided to take it to a shop to have it done instead. Anyway, come to find out. . the block is cracked. . well. . where the starter mounts to the block, on that lower corner, tha aluminum broke cleanly off. Anyone ever heard of that happening or know a good fix without taking the motor out. They are going to see about welding the piece back on with the motor in the car but doubt that's gonna work. I hate to spend around $1500 to pull the motor just to weld one small spot. If anyone has heard of this happening, please let me know what was done to fix it. Thanks guys!!
Old Mar 2, 2006 | 07:28 PM
Default RE: Starter breaking the block????
Never heard of it happening
Old Mar 8, 2006 | 01:22 AM
If it's a good amount of surface area, you might want to try an aluminum epoxy. It's almost as strong as a weld. I would guess that your block casting had a flaw in it that allowed a crack to propogate until failure. Have a metalugist take a look at the broken off piece. You may have a case.
Good luck.
Old Jun 4, 2009 | 11:07 AM
mikearr's Avatar
Default Final Result
I'm now looking at the same problem with a broken starter mount on the engine block. Did you ever get yours repaired? Did the engine come out?
hester
Dec 6, 2007 12:11 PM
57halfton
Mar 23, 2006 07:41 PM
Lee Willis
Nov 10, 2005 09:14 AM
9C1 WS6
Oct 10, 2005 11:46 AM
jeepin45
Aug 23, 2005 12:44 AM
