85 fuel trouble
Old Mar 31, 2006 | 05:13 AM
frank85's Avatar
Default 85 fuel trouble
after driving car to normal operating temp. and I shut car off it is dumping fuel causing it to flood. I did not seem to have this problem until I installed high volume fuel pump. But it did not happen right after installing. I think it might be the fuel pressure regulator maybe to much pressure on regulator. Hoping someone else has had this problem and could help me with a answer it would be greatly appreciated thanks for any help you may offer me. Frank85
Old Mar 31, 2006 | 04:49 PM
corvette king's Avatar
Default RE: 85 fuel trouble
are they stock injectors. when you put in a high volume fuel pump you must replace the regulator and injectors to handle the fuel pump.that the mass flow of fuel and pressure the pump is putting out.
slayerz06
Feb 10, 2009 10:48 PM
Texas Jim
Mar 6, 2008 11:48 PM
Black86vette
Nov 10, 2006 10:00 PM
73Vette
Aug 30, 2006 01:15 PM
frank85
Mar 31, 2006 11:29 PM
