85 fuel trouble
after driving car to normal operating temp. and I shut car off it is dumping fuel causing it to flood. I did not seem to have this problem until I installed high volume fuel pump. But it did not happen right after installing. I think it might be the fuel pressure regulator maybe to much pressure on regulator. Hoping someone else has had this problem and could help me with a answer it would be greatly appreciated thanks for any help you may offer me. Frank85
are they stock injectors. when you put in a high volume fuel pump you must replace the regulator and injectors to handle the fuel pump.that the mass flow of fuel and pressure the pump is putting out.
