1970 Corvette
Old Apr 13, 2006 | 12:18 AM
70convert's Avatar
Default 1970 Corvette
1970 CORVETTE 350 AUTOMATIC (400 TURBO WITH A MILD SHIFT KIT) CONVERT. THIS IS A GREAT RUNNING AND GREAT DRIVING VEHICLE. BOTH HARD AND SOFT TOPS, WITH POWER STEERING, POWER BRAKES. I WAS GOING TO GET A NEW REAR FIBREGLASS SPRING PACKAGE, IT NEEDS TO BE UPDATED. THE CAR HAS A GREEN TEAL PAINT THAT WAS DONE A COUPLE OF YEARS BACK AND STILL LOOKS GREAT TODAY!
I JUST HAD THE FRONT END OF THE CAR REBUILT. INCLUDES LOWER BALL JOINT, BUSHING AND AN ALIGNMENT. INTERIOR IS ALL ORIGINAL OR WAS REPLACED. INTERIOR LOOKS GREAT. EXTERIOR HAS A COUPLE OF CHIPS/SCRATCHES, SOME WERE TOUCHED UP, BUT STILL LOOKS GOOD. WHERE THE HARD TOP SITS ON THE BACK COVER THERE ARE SCUFFS AND SCRATCHES FROM BEING REMOVED AND REPLACED. A STRIP OF THE BODY IS MISSING WHERE THE DRIVERS DOOR IS. i DON'T KNOW IF IT IS SUPPOSE TO BE THIS WAY DUE TO THE KIT OR NOT, BUT DOES NOT AFFECT THE FUNCTIONING OF THE DOOR. THE DRIVERS SIDE WINDOW IS KIND OF TOUGH TO ROLL UP. THE TRACKS CAN PROBABLY USE A LITTLE GREASE. IT HAS A CUSTOM BODY KIT ON IT AND THE FRONT NOSE CLIP TILTS FORWARD. THE SOFT TOP IS NEW AND HAS RARELY SEEN THE SUN. THE CAR IS ALWAYS UNDER COVER.
THE CAR SHOWS 25K, BUT THE SPEEDO IS NOT FUNCTIONING PROPERLY. THE PREVIOUS OWNER CLAIMED IT STOPPED WORKING ABOUT A YEAR AGO. THE MILEAGE SHOULD BE CLOSE TO BEING ACCURATE AT 125K. THE FACTORY TACH DOES NOT WORK DUE TO THE IGNITION SYSTEM HAS BEEN UPGRADED TO HEI. THE STOCK CLOCK, WATER TEMP, AND ENGINE TEMP GAUGES DO NOT WORK, BUT HAS AN ADDITIONAL GAUGE PACKAGE UNDER THE HOOD FACING THE DRIVER.
THE FRAME AND UNDERCARRIAGE ARE IN GOOD CONDITION WITH MINOR SURFACE RUST. THE CAR HAS A NEW BRAKE MASTER CYLINDER. THE CAR CURRENTLY HAS HEADERS AND SIDE PIPES. I'M NOT SURE IF THE BODY KIT INCLUDED THE HEADERS AND SIDE EXHAUST, BUT IT IS A GREAT LOOKING COMBINATION. THE HARD TOP IS UNFINISHED AND NEEDS A HEADLINER AND TO BE PAINTED.
ASKING $15k
[IMG]local://upfiles/1379/C71A781135C242129FDB4981AECF2E22.jpg[/IMG]
[IMG]local://upfiles/1379/8A5E2B1B8FA8444A92BB119BCF6DBCB4.jpg[/IMG]
[IMG]local://upfiles/1379/D11807D8E0084706916EDB76EF00C6DE.jpg[/IMG]
[IMG]local://upfiles/1379/6E64D88F134D45AFAE1583399A4A1868.jpg[/IMG]
[IMG]local://upfiles/1379/15B41E2C068B4567A45CDB73CCCB74CD.jpg[/IMG]
RacingJunk
Mar 27, 2015 03:06 AM
leamangriffin
Apr 29, 2012 09:40 AM
sbeasley
Jun 5, 2008 06:53 PM
university
Jul 1, 2006 01:56 AM
Bearcamp
May 29, 2006 09:20 PM
