Rear end question
Old Apr 22, 2006 | 12:38 PM
force120's Avatar
Default Rear end question
How would I flush rear gear oil?.Is there a pump to avoid dissasembly?
Old Apr 22, 2006 | 11:24 PM
corvette king's Avatar
Default RE: Rear end question
there are pumps,but you are going to want to take the cover of to inspect the gears for wear and chips,and u will want to wipe out the case clean before instaling the new oil.
[IMG]local://upfiles/1664/1436C0146CBE4E0FB289E0767D7511F2.jpg[/IMG]
Old Apr 27, 2006 | 01:40 AM
shark79's Avatar
Corvette King is right, be sure to inspect the inside. Depending on what year you have you may have alot of wear inside. In the late 70's GM didn't heat treat the half shafts. When I rebuilt my 79's differential the half shafts had mushroomed inside the differetial and damaged alot of the gears, and the clutchs were in pretty bad shape.
MACTANK
Jun 9, 2008 07:13 PM
Gonzo13
Dec 25, 2007 09:40 AM
way235
Nov 10, 2005 04:14 PM
nmoser01
Sep 6, 2005 06:13 PM
jerrys
Corvette C6 Z06
Sep 3, 2005 07:13 PM
