No start, no crank
Old Jul 29, 2006 | 09:35 AM
joeinindy's Avatar
Default No start, no crank
My 88 vette at times will not turn over, all lights ect. work fine but the starter acts as if it's getting no power. Could this just be a dead spot in the starter or should I check elsewhere? The car has 31,000 miles and trying differnt keys and cleaning the key chip makes no differance. This only happens rarely and eventually the starter will crank and it starts and runs fine, any help would be great.
Old Jul 29, 2006 | 12:26 PM
Crash's Avatar
Default RE: No start, no crank
I am sure you have done all this already but just to go over the basics . Battery cable conections clean and tight ( both ends ) does it click every time you turn the key ( sound of the click coming from under the hood ) if so it could be the solinoid has a bad spot ( new solinoid or starter ) this is a common problem with chev starters, the contact disc wears out in the solinoid . I use to pull it apart and flip the contact bolt and disc 180 . If it has to do with the key chip I am not familliar with the diagnosis of that . I have heard that the motor will turn but not start if the chip is out of the key, but have never seen it . good luck
Old Jul 29, 2006 | 04:12 PM
3BlkC4Ragtop's Avatar
I had my local hardware store take a shot at an ignition key for my '89.
The key fit fine.. turned the ignition right over.. but did not engage the starter.. nothing .. nada.. put my normal key in and fired it up and drove it right home. On my '89.. wrong chip in key means no starter moving at all.
Old Jul 29, 2006 | 09:38 PM
raisinbran's Avatar
bang the starter with a hammer and see if that works.
Old Jul 29, 2006 | 10:14 PM
Without the right resistance reading on the VATS system and the system won't work.
Old Jul 30, 2006 | 03:17 PM
d93vette's Avatar
was up, clean the key, the try again. you have to wait 3 min for the ecm to reset if it didn't read the key.[atleast with my 93]
Old Jul 31, 2006 | 08:28 AM
joeinindy's Avatar
Checked battery cables, switched keys, and there is no click sound, cleaned key. It will do this even if the doors have not been locked or the key removed from the ignition. Any other suggestions?
Old Jul 31, 2006 | 09:51 AM
Do you still have lights? Does the dash light up and not get dim when you rotate the key to start position? If you have a voltmeter, check your battery voltage. You should have at least 12.5 v before starting. If all are ok, you might be experiencing key reader problems. Built into ignition switch.
Scott Luttrell
Jul 13, 2015 11:06 AM
bollaman
Apr 20, 2009 02:15 PM
huggyboy01
Corvette C5 Z06
Oct 13, 2007 09:49 PM
Dashti
Jun 17, 2007 09:48 PM
87vertvet
Aug 24, 2006 11:43 PM
