Corvette Forums Help & Suggestion Center Need help with Corvette Forums? Ask. Have a suggestion to better CF? Tell us here.
How-to: Adding your Avatar
Old Nov 2, 2006 | 03:46 PM
DevilsReject's Avatar
Default How-to: Adding your Avatar
Avatars are the pictures that appear beneath each member's name on the left hand side of each post. These are usually either pictures of cars, animated icons, artwork, or even pictures of that said person. They MUST be 145x145 in dimension and no larger then 10kb in size. If you have a properly sized Avatar, you can then proceed to upload it. If not, you need to edit/resize the file to make it fit. This can be done by using a photo resizing program such as Microsoft Office's Picture Manager, Microsoft Paint, Adobe Photoshop, Lview Pro, Paintshop Pro, and even some other programs as well.
Need help resizing your pictures to make them fit? Here's a quick, easy way if you dont have any photo resizing programs....
1) Go to www.resize2mail.com
2) Select option below (25% smaller 75%smaller etc..)
3) Click chose, and chose the correct image
4) Click ok
5) Right click on image after it is loaded and save as (desktop)
If your picture meets the requirements of being 145x145 or smaller, and is 10kb or less in file size, you can now proceed to the next part....which is getting it uploaded!
Along the top of every page you should see a list of words like Member List, My Profile, Inbox, My Forums etc etc. You want to click on My Profile.
[IMG]local://upfiles/3514/2F21FC8A362A4FFDAE605E5BACB1C745.jpg[/IMG]
This will take you to your own personal profile page that will let you edit certain information about you.
[IMG]local://upfiles/3514/BAE1E65A2C3C4E588F83B0F60E81DC5E.jpg[/IMG]
Scroll down about midway thru the page and you should see a section that says My Avatar.
[IMG]local://upfiles/3514/5A1A9CB8D8294AE7AAE3408D5279625A.jpg[/IMG]
Make sure to select the Upload my picture box. Click on the text and a window will pop up.
[IMG]local://upfiles/3514/255C120C58044587AAF6045B36B063CB.jpg[/IMG]
This will bring up a window that will let you browse to where your picture is stored. Click browse and this will let you look for your picture. I tend to save mine to the desktop when I'm going to upload a picture. I find that it makes it much easier to find when doing things like this. Once you find your picture, highlight it. Once you've highlighted your picture, you should see this....
[IMG]local://upfiles/3514/69108FFCF0E4414A9CE5E14D3AF90B23.jpg[/IMG]
Now click open, and you will get a new window to appear...Click Ok
[IMG]local://upfiles/3514/F7318E60613F4D8DAEE336B4251A1CDE.jpg[/IMG]
Another new window. Click OK. The window will disappear and the My Profile page will reappear.
[IMG]local://upfiles/3514/4843AB8E2ECB4F448D3B6DBC3A17B68E.jpg[/IMG]
Scroll down to the bottom of the page and click APPLY.
[IMG]local://upfiles/3514/1E5C1BBE9EB143889D8C7F4698CF7783.jpg[/IMG]
Then when the page refreshes, click OK.
[IMG]local://upfiles/3514/3A059684A48F4461B6CDE99D1D220613.jpg[/IMG]
You MUST follow the last two steps or the avatar will not load.
If you did this right...you should now see this when you make your posts...
[IMG]local://upfiles/3514/E3F6FC26779D48AD8D9861C76C2E3A31.jpg[/IMG]
Old Nov 29, 2009 | 02:45 AM
D.Waype's Avatar
Default How to Adding your Avatar
To change your avatar.
goto user cp
then edit options
then scroll down to change avatar
click it
a new page appears
normally u can either select from the available list
or upload a custom one
right now size is limited to 100 x100 pixel
if your image is too big resize with photoshop,acdc etc
thats all folks.
hey Muddmachine thanks for the mod status,Im a test pilot
now.thankx again
Old Dec 6, 2009 | 01:16 AM
sunsets09's Avatar
what the ***** I still cant post pics on posts. I just signed up for the photobucket thing and the code it gives you to post inside forums like this doesnt work. Is it because Im using a Mac?? this computer is less than a year old but I know Macs dont always sync with harmony with other programs since Ive had oddball problems like this before where pictures tend to be a common issue when I try uploading them. I cant even upload an avatar or profile pic, it always comes up error since I first joined this forum. Am I missing something or what?? lol
Old Jan 6, 2010 | 04:10 AM
crearry09's Avatar
Im just thinking there should be a How-To somewhere so that people know how to do it. On every other forum I am part of, there is a section of your profile or control panel that has options to upload photos into your personal gallery. I just have links in my sig to pages on other forums that hopefully other people can view, but I should probably make a link to them from a thread on here...
Old Dec 12, 2013 | 07:51 AM
RickensMiley's Avatar
Banned
goto user cp
then edit options
click it
a new page appears
thats all folks.
now.thankx again
Now that was the easier and smaller explanation to that. Thanks
C3 Starship
Mar 4, 2009 06:10 PM
jsholm2
Mar 28, 2008 03:25 PM
O4XC5
Mar 1, 2008 10:16 AM
chargedvette02
Aug 15, 2006 03:10 AM
