Lighting
Old Sep 12, 2005 | 09:43 PM
85Corvette's Avatar
Default Lighting
The instrument panel lights dont come on, but the directionals and highbeam indicators stay on, anyone know why this is happening?
Old Sep 19, 2005 | 07:32 PM
crvttbass's Avatar
Default RE: Lighting
Does the rest of the instuments work correctly? If so I haven't a clue. If not it sounds like the plug may be on wrong.Did this start all at once? Or was it after some dash work? I know this sounds abvious but since noone else responded I thought I'd throw it out there.
Old Sep 26, 2005 | 07:45 PM
85Corvette's Avatar
The rest of it works fine, it just did it by itself, I havent done any dash work.
Old Sep 29, 2005 | 08:09 AM
mdsbch's Avatar
The symptoms you are having, digital dash dark and turn signal and high beam lights on, are the same ones I had about a year ago. The problem was the ground on the instrument cluster. What I did was run a wire from the grounds on both the connectors to the digital dash through the firewall (in an empty spot where all the wires go through next to the brake). I ran it directly to the battery ground on the frame. I haven't had any problems since. Also, while you have the cluster out, you might use some electric contact cleaner and clean the contacts.
DLC360
Jul 4, 2015 09:20 AM
gym4866
Apr 13, 2009 04:21 AM
gym4866
Apr 12, 2009 09:35 PM
76yellowbrd
Nov 19, 2006 08:59 PM
stubbs
Oct 29, 2005 02:25 AM
