Water Pump Leaking
Old Oct 6, 2005 | 01:52 PM
farhan's Avatar
Default Water Pump Leaking
Hi, I smell a strong Anti-Freeze odor when i open the hood of my 2002 coupe. One day i could see spots in the garage from the leak. I got it checked by a dealer, they said the leak is in the water pump. According to the dealer the cost is $900. I checked the price of pump online, its around $160. The dealer sells it for around $300. To me, $900 seemed high to get the water pump changed. Anyone has any suggestions. ? If somebody from washington metro area (VA, MD, DC) can suggest a cheaper and reliable corvette mechanic, i would really appreciate. I live in Alexandria, Virginia.
thanks.
farhan.
Old Oct 6, 2005 | 05:02 PM
Default RE: Water Pump Leaking
Again, I never recommend the dealer for work unless it is warranty. Not all of them are bad/high but most of them are. That water pump is not a hard job and should not in anyway cost that much. Take it to another mechanic and let them do it is my suggestion. The water pump is a simple common item for mechanics so it is not like it is some delicate item that you have to fear them messing up your car doing.
Old Oct 6, 2005 | 10:01 PM
SkipS's Avatar
Recommend you get another opinnion. It may or may not be the pump. Could be a loose hose clamp, split hose. I go with the Danase suggestion. Unless it is warrenty work, avoid the dealer. One suggestion about finding a mechanic. Check the National Corvette Owners Association web site. You may need to become a member, but they have a list of recommended Corvette shops.
Old Oct 7, 2005 | 02:54 PM
farhan's Avatar
Thanks guys... i will get it checked by an independent mechanic, over this weekend. I got a labor quote of $160 for water pump change from one shop i called yesterday.
Again thanks for your time.
riley6riley
May 31, 2007 06:18 PM
231SIX
Aug 23, 2006 12:57 AM
73Vette
Aug 14, 2006 01:11 AM
duneadx
Jun 26, 2006 07:13 PM
vwygonik
Feb 14, 2006 03:37 PM
