Rear Wheel Noise "Clicking"
Old Oct 10, 2005 | 05:34 AM
Daveloves's Avatar
Default Rear Wheel Noise "Clicking"
Right Rear Wheel Noise (Clicking) Hi, I have a 1980 and the problem that seems impossible to solve. At first it was a clicking noise that got louder and louder and i discovered it was bad U-Joints, which i changed both on the right axle. Shortly afterwards the noise returned so i changed both on the Left Rear, with no change i went and did the driveshaft too. Noise still there, i then again replaced both on the right rear axle and the noise disappeared for the first 10 miles and now is back and gets louder the more i drive. Forward, backward, slow or fast. Is very constant and some who have listened said it sounds like it is every 180 degrees. Have checked E-brake shoes and pads etc. Replaced both Calipers, Rotors, Pads. HELP NEEDED Thanks Dave*
Old Mar 31, 2006 | 01:49 PM
frank85's Avatar
Default RE: Rear Wheel Noise "Clicking"
hi check your wheel bearings it could be that good luck.
Old Mar 31, 2006 | 04:52 PM
corvette king's Avatar
sounds like wheel berings to me [axel berings],
Old Apr 29, 2006 | 04:32 PM
jaki30's Avatar
The 1980 Corvette had a problem with an over machined part in the rear. My 1980 was
fixed with a set of washers under warranty. Apparently, the joints loosened up under
stress and what you hear is the part moving in/out as the axels rotate. It took Chevy
3 months to figure out what was wrong and come up with a fix.
My Ws6
Apr 1, 2014 04:08 PM
kosio
Nov 8, 2008 01:52 AM
samurai2000
Oct 2, 2007 08:27 PM
Lucinda
Jan 27, 2007 02:05 PM
Daveloves
Oct 14, 2005 10:58 PM
