Strange Clicking Noise in Right Rear Wheel
Old Oct 11, 2005 | 06:28 AM
Daveloves's Avatar
Default Strange Clicking Noise in Right Rear Wheel
Right Rear Wheel Noise (Clicking) Hi, I have a 1980 and the problem that seems impossible to solve. At first it was a clicking noise that got louder and louder and i discovered it was bad U-Joints, which i changed both on the right axle. Shortly afterwards the noise returned so i changed both on the Left Rear, with no change i went and did the driveshaft too. Noise still there, i then again replaced both on the right rear axle and the noise disappeared for the first 10 miles and now is back and gets louder the more i drive. Forward, backward, slow or fast. Is very constant and some who have listened said it sounds like it is every 180 degrees. Have checked E-brake shoes and pads etc. Replaced both Calipers, Rotors, Pads. HELP NEEDED Thanks Dave*
Old Oct 11, 2005 | 08:31 AM
revheadron's Avatar
Default RE: Strange Clicking Noise in Right Rear Wheel
does your car use chrome dress rims on steele wheels? if so check that one of the chrome trims isn't causing the problem
Old Oct 14, 2005 | 10:58 PM
ddegrave's Avatar
I had similar issue "clicking" with my 72 Coupe. Turned out to be rear whell camber adjustment. Adjusted camber to spec and clicking went away.
My Ws6
Apr 1, 2014 04:08 PM
kosio
Nov 8, 2008 01:52 AM
samurai2000
Oct 2, 2007 08:27 PM
Lucinda
Jan 27, 2007 02:05 PM
Daveloves
Apr 29, 2006 04:32 PM
