C3 Power brake vacumm filter
Old Jul 5, 2007 | 07:37 PM
gigabyte's Avatar
Default C3 Power brake vacumm filter
all the books I read on this gizmo states that it needs to be positioned vertical. WHY? It is a filter with no moving parts and nothing inside other than filter media. air will pass through it either way either end. the attachment with the 90 degree turn goes on the top.
what will happen if it is not on the vertical? I do know its use and know NOT to unhook it. If you do unhook this hose you can still stop.......eventually and not at the planned point and not on a dime.
Old Jul 6, 2007 | 08:47 PM
Default RE: C3 Power brake vacumm filter
Hi, where is this vacuum filter? PG
Old Jul 8, 2007 | 06:14 PM
gigabyte's Avatar
Between brake booster and carb
Old Jul 8, 2007 | 09:55 PM
Hi again, you got me on this one gigabyte, I have a check valve pluged into my booster and a hose to the carb and no it doesn't matter haw it's pluged in. Are we talking about the same thing? PG
Old Jul 9, 2007 | 05:02 PM
gigabyte's Avatar
Yes we are talking about the same thing. I also have a check valve plugged into the booster and about six inches up the hose is the vacuum filter which is on a bracket bolted to the intake, with several more inches of hose going to the back of the carb. The 79 chev corvette repro shop manual shows a pic of the whole setup in chap 5 listed as Fig 5-1 and labeled power brake vacuum hose filter
Old Jul 9, 2007 | 05:13 PM
ORIGINAL: gigabyte
Without a pic, or the machine itself to look at,I'm guessin' it's so you don't pull the element into the carb...
Old Jul 9, 2007 | 08:39 PM
78buckshot's Avatar
Some years ago I read about the vacuum filter helping to keep gasoline vapors from condensing in the booster and deteriorating the diaphram. Thats all I have to say about that.
Todd TCE
Aug 25, 2015 09:55 AM
blk84vett
Jan 11, 2009 09:40 AM
greenwoodC4
May 9, 2007 04:45 PM
57halfton
Sep 5, 2006 02:49 AM
HeeBGB
Oct 30, 2005 09:32 PM
