'71 wiper switch ground
Old Oct 29, 2005 | 04:46 PM
keverson's Avatar
Default '71 wiper switch ground
I have narrowed my wiper problem down to a grounding issue. If I ground the switch with a test light, the wiper door opens and the wipers engage. Does anyone know where this switch is grounded or if there could be another solution? I am going to purchase a build manual, but would like to get this corrected sooner.
Old Nov 2, 2005 | 11:33 PM
johnc's Avatar
Default RE: '71 wiper switch ground
i just posted a response to your problem,but now see you seem to have hit on answer,good,disregard my response and look at connector in back of switch,three prong i think,one of them is ground,if you hook a test light to connector,you can id which one is ground go from there,jc
Old Nov 4, 2005 | 09:26 PM
keverson's Avatar
Thanks. The switch has a light blue, a dark blue and a black with white stripe wire. All are hot depending on the position of the switch. The black w/white is hot when the switch is pushed in the wash position.
TripleBlackC5
Oct 15, 2007 07:14 PM
My93Vette
Apr 20, 2007 02:51 PM
jdtoad22
Apr 17, 2007 12:45 PM
Bagpipingjake
Jun 20, 2006 02:02 AM
poxic
Jul 24, 2005 01:58 PM
