exhaust through intake
Old Nov 23, 2005 | 07:39 PM
khane1's Avatar
Default exhaust through intake
Was driving Vette recently after it sat for a month without running. After about 5 minutes of driving backfired and valves started rattling. Broke it down and discovered broken push rod on intake valve. Replaced pushrod and turned over to check reaction. Thinking might have sticky valve put small amount of tranny fluid in valve port to soak overnight. When I turned it over, compression forced some tranny fluid to blow from intake. Seems valve may be sticking open to some degree.... appears correct height when supposedly closed. Any suggestions what problem might be before removing head to check. Engine is a 383 stroker with roller rockers and hydralic lifters.
Old Dec 6, 2005 | 01:47 PM
SkipS's Avatar
Default RE: exhaust through intake
Do a compression test on all the cylinders. Then compare the readings. That will tell you a lot. Low compression can indicate a stuck valve among other things. Did you over rev it? That can bend a valve and leave it hanging open.
jwjones5
Jan 21, 2011 10:29 AM
aimee
Apr 4, 2009 04:29 AM
SVT Rob
Apr 12, 2007 07:48 PM
01darkz
Corvette C5 Z06
Jan 19, 2007 07:06 PM
buck
Aug 21, 2005 08:12 PM
